- Jun 9, 2004
- Los Angeles, CA
I just build a comp, and am using SATA for the first time. During windows install, it said press f6 to load third party adapters, i did this, using the floppy disk that came with the NF7-S motherboard. I loaded the drivers, and it began formatting and installing. After it finished, it went back to the dos screen and it said "please remove disk or other devices" meaning the floppy driver disk. I did that, and it began loading windows setup again. Windows is already installed, why would it load windows again? when I remove the windows disk, it says "boot disk failure, insert the system disk to continue" What should i do here!?!?
