- Aug 9, 2003
- Naperville IL
I'm planning on buying a gig of ram in a week for my NF7-S ver 2.0. so far I've narrowed the choice down to one of these 2 sets of ram.
1) Corsair TwinX 3200LLPRO
2) Mushkin PC3200 DDR 222
My goals for my system is to be able to run the FSB at 220mhz or higher with the lowest latency I can.
The CPU I have is a unlocked 2500 Barton and for cooling I have a Danger Den Maze 4 with a Danger Den NB block and a Danner Mag 500GPH pump. So I should be ok in the cooling Dept.
Please help me make the right choice out of the two or recommend me some other ram that might be better.
Thanks
Thanks
