85°C?!?!
Dude lookout!!! Try not to burn your chip, really.
If you see it raising above 75°C just drop the hammer and stop the tests for your CPU sake.
Arctic Freezer Pro is a good "middle-class" cooler, but not the best.
Also, your case doesn't seem to have an optimal HAF (High Air Flow).
For my experience: Setting high FSB gets your system warmer.
What I prefer to do, is to play with the multiplier. Of course, once you hit your multiplier limit you have to mess with the FSB.
Why don't you try out my config?
Set 400 FSB and 8X Multiplier. That means your RAM will be synchronous 1:1 and it will perform better for dual-channel.
Let me know if it worked out
