Thanks Mysterfix, but I'm not out of the woods yet. This afternoon I decided to switch back to my Swiftech heatsink. I wanted to see how much warmer the temps would be in case I went to remove the IHS and go with a safer heatsink to attach to the CPU. Well, I switched everything and when I went to boot I couldn't get into windows. I tried lowering to stock speeds, safe mode and last known working config. I ended up doing a windows repair installation. After, when I kicked it up to 9x280, I got into windows but then got the BSOD in about five minutes. Then I brought the system back down to stock speeds and reinstalled the XP90. (The temps were about 3 degrees warmer with the swiftech) I put a little extra AS5 as I had noticed something less than a fifty cent piece cover last time. I also slowed by ram a tad to CL2.5. Now, it's back up to 9x285 and running great. I believe the problem was my ram timings. Though they ran fine with a 166 divider and CL2 timings at 9x282 for many months with my winchester, I think I corrupted something in the registry and it was crash and burn time.
Now my big decision is whether I remove my IHS? My load temps are 50 and idle is 41. If I do it and use the XP90 it could make a big difference, but I don't want to crack the core with that sideways mount. I really don't know what to do, but I'll have to do something before the weather gets warm, because this CPU is still hot at stock speeds.
