Tru2ya said:Because i tried the higher fsb at lower multipliers and still cant finish 3dmark. Plus, i said i had it at 159fsb at one point because my previous chip wouldnt go beyond that. That means my 1/5 divider didnt kick in. So everything was running fine that far out of spec. 159fsb with 1/4 divider is way more out of spec then a 175fsb with a 1/5 divider.
BioS said:
As what i'll try to low my mem timing and more vmem. I don't know if you have tried thoes undocument jumper to increase to Vmen? Heard it can up to 2.99v by connectin the jp1 & jp2 jumper.
Tru2ya said:
I could try but again when my fsb was at 159mhz, my memory was running at 370mhz at the time. With 175fsb, it runs at 350mhz. I checked the forums on my board, and it was recommended not to go past 2.75v which its on. Also my memory is guranteed to run at 400mhz regardless.
Tru2ya said:Well, now i'm starting to hear that my board doesnt support the 1/5 divider for the pci. I checked sandra and it shows my agp running at 88mhz and pci at 44mhz. I really don't understand how others were able to hit 200+fsb
Krowa 02 said:I really think the AGOIA Y cpus that popped up last month are a better buy. AMD has done just what Intel did almost a year ago, accept intels .13 cpus overclocked like crazy. I have reached 1.9 on this agoia I have right now, most likely could hit 2ghz, but the problem is my HD **** cans on me. Just my 2 cents.
