I am in the understanding that the comparison is hard to make because of the different Mobos that is why I asked the question regarding this issue because the Asus was able to read CPU Die temp and the Abit reads the thermistor in the socket and granted the Asus had a thermistor as well and it read higher than the die because the peltier cools directly at the point of contact, that beimg the die.. But the Abit reading this higher temp tends to Throw off the Bios high temp protection but I still am getting the high temp using my MCX-462+t which on the old board and newer stepping CPU I got around 10 to 15c and now its in the 50's which is not good. My main thought is that the Asus was unable to run as high a FSB it ran into a wall at about 195 thats with it vmodded on the Vcore, VDimm, and the chipset. The Abit easily hit 210mhz FSB out of the box and that makes me wonder if its the high bus rate running the die so much hotter at lower voltages. My MCX-462+T will make ice on it after being plugged in about 2 minutes when not on the chip so I know its working properly and so will the MCW-462+T I have on my WC setup so I'm at a loss as to why the chip would be so hot in this new board if its not because of the high overclock, I've got it at 217x11 right now at 1.8v and I am getting 50c at the thermistor, so if a WC setup can't cool it at that speed what can I would have gotten a promethia if I knew thats what it was going to take...
