I'm not a huge fan of Intel - Never have been. It's not something I can get over, and I've always done fine with AMD, which is the main reason I'm sticking with the 8350. According to
http://www.cpubenchmark.net/high_end_cpus.html, the 8350 rates up with several of the i7's.
I prefer the look of the HAF-X compared to a lot of the others. Size isn't an issue, andthe possibility of crossfiring two 7950's exists. I also expect the tower to last me several builds, as my current Antec 900 has. I find it to be a bit tight to work in, though.
I probably misspoke, when I admitted to being lazy. I'm aware of how to maintain the system.. And if/when something comes up (As I'm sure it does), I know there're a dozen stickies here that probably have the info on how to fix said issue.. Reading it all now though, will probably only confuse me and I'll have forgotten it when the issue arises anyways.
I'm not a fan of the AiO cooling systems, for the simple fact that I will want to upgrade. I'm starting with one card now, but I do plan on getting a second - When that happens, I'll end up making a second loop for the two cards, or add a second radiator to the main loop - Something I'll look into when it comes closer to getting the second card.
As far as use, it boils down to gaming. There is a lot of multitasking, in that I've been known to multibox with different games running at the same time (An example being GW2 running on one monitor, SWTOR running on another.) Or, multiboxing in the same game. I'm also an avid believer of buying more than you need, so you can grow into it. Buying for what you need now, limits you.
Other than that, I'm not sure what else info you need.... Seems to me that, one way or the other, I'm going to end up doing a watercooled system - I'm just here to get the assistance to make sure I do it right for what I want, regardless of what I need...
And yes, EarthDog is right. This thread's to focus ont he watercooling side of the build - I've got the build stuff up in the general forums, looking for advice on the hardware there.. But I've think I've pretty much settled on what I'm getting. Just need to go look up the blocks and such to fit everything.
