Anyhoo, Your very special and really never needed to do research etc, your an experimenter and a old timer who does fine with his methods and it's entertaining and fun to read about.
Mm. Since I got everything dried, I've been playing with the fittings.. Screwing them in, unscrewing them. Putting a peice of my scrap hose on, screwing the compression down to it, tugging on it at different levels of tightness.. just random things with it. I think I'm glad I went with those, over the old clamp style.
Sure, you can say they are better. You have only dealt with one, I have only dealt with barbs myself. They are the same if done right. Compressions are prettir though.
As for the water, I say boiling, but it was water from the faucet on 'hot' as hot as it'll go. Hotter then I like to keep my hand in for any extended period of time.
Did you do the 'dance'? Maybe missed the sticky? It breaks loose any bits in the rad.
It's good to know I don't need to boil the distilled water though - I couldn't see anything stating that for sure, one way or the other. That saves some time... Once I get that tomorrow, I'll flush the whole system a few times with it. As far as filling the system, when it comes time to that, I was figuring I'd use a funnel and pour directly from the distilled water jug. That plan is only good, if everything else works out though.
I do have a question that I've never considered, in my years of computer building... When all the hardware comes in, I was planning on putting everything into the case in order to measure my tubing.. Get my tubing cut, and then take everything out of the case to put it together. Put it back into the case, fully assembled.
Sure, that would be fine, and good practice. Make sure you think and rethink tube routing. No harm in making a piece of hose an extra " long. You want the hose to be a good 90 degree into any fitting. Leaks happen that way once they are stressed. That's where the expensive BitsPower angled rotaries are golden.
My theory for this is that I can tighten down the compression clamps easier, and tighter, while it's outside of the case. My question though, is it alright to put the blocks on their respective components without any thermal paste? As long as I don't turn it on? Seems like it'd be fine.
Yep.
And, will it be safe to run the system for a leaktest without the killcoil?
