- Jan 21, 2011
- Las Vegas
I'm going to go into detail, but I hope that doesn't deter you from reading.
The problem:
What I'm using:
What I've done:
What I'm going to do:
The long version:
At this point I'm stuck with the components I have, so I'm either going to use it or leave it in a box for a future build or sale.
I'm happy with the temperatures I have with stock cooling, but I wouldn't mind getting them a bit better, so enters the A70.
The trouble I ran into just before I was about to grease my CPU and drop the fan on, was I looked at the RAM and noticed it was a bit close to the CPU. So, I did a un-greased check and found to my dismay that the fins from the A70 sat on the fins from the RAM. It also held the A70 at an angle. If the RAM was about 3mm shorter, or the heatsink about 3mm taller it would've been a perfect fit.
If this was an Intel build I could use the Intel installation bracket and swivel it 90 degrees. This would allow me to leave 1 fan off and it would fit in a North-South direction with the RAM free on one side as shown by someone else's picture below.
However, because it's an AMD build, the bracket will only allow it to fit in a West-East direction.
I have confirmed that I shouldn't have to take it out for some time, so I believe I'm ready for a modification.
My first thought was to trim about 3/4 of a centimeter off of a few fins on the A70 so that it would then fit. My reasoning being that there's still plenty of fins to go around. I would also have to trim some off of both fan housings, but that shouldn't cause a problem. The problem would be that if I did that I would then of course be losing efficiency on a well designed product, and also that the RAM would then be much closer to the heat pipes than they would like.
After running this by my friend I was given the suggestion that I should consider instead trimming off part of the fins on the RAM as they don't really help much anyway. The fins themselves are already pretty flimzy (I've read that some people have broken them off on accident) and I imagine it wouldn't take very much effort to snip them. There's 2 things that concern me in this operation.
Your thoughts please.
The problem:
My new heatsink sits on top of the RAM preventing it from seating properly on the CPU.
What I'm using:
CORSAIR A70 120mm Dual-Fan CPU Cooler
http://www.corsair.com/cooling/air-series/air-series-a70.html
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9B. 2 sets for a total of 16GB.
http://www.corsair.com/vengeance-8gb-dual-channel-ddr3-memory-kit-cmz8gx3m2a1600c9-279.html
ASUS Crosshair IV Extreme AM3 AMD 890FX SATA 6Gb/s USB 3.0 Extended ATX AMD Motherboard
http://www.asus.com/Motherboards/AMD_AM3/Crosshair_IV_Extreme/
AMD Phenom II X6 1100T Black Edition Thuban 3.3GHz, 3.7GHz Turbo 6 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Six-Core Desktop Processor HDE00ZFBGRBOX.
http://www.overclockers.com/amd-phenom-ii-x6-1100t-review
What I've done:
A little research that all points to using a different heatsink.
One of 2 things.
- Either snip the A70 so it fits over the RAM, or
- Snip the RAM
The long version:
- That long block in the middle that I perceive as the handle. What are the chances that there's a critical piece of hardware inside?
- The heatsink is easier for me to replace than the RAM if it is destroyed in the process.
