- Jul 31, 2001
- Los Angeles County
New SETI machine with Epox 8K7A - Advice
Got my new Epox board today. The processor won't be here until Friday or Monday - Athlon 4 1.2. I had planned on setting the CPU multiplier to x9 and running the fsb as high as possible. The memory for this board is Corsair XMS PC2400 - and cooling will be the Global Win CAK. (Haven't tried that one yet.) Of the copper HS I have used Hedgehog, ThermalRight, SwiftTech 462, and SilverMountain.
OK, for those of you using the 8K7A board, just a couple of questions.
For the SDRAM timings 8882222 ?
Vcore adjust +.1v +.2v +.3v +.4v ?
DDR adjust - are you upping the voltage ?
CPU clock - at what fsb are you getting the most stability running SETI 24/7 ?
Lastly, and excuse my ignorance or blindness - but where do you set the PCI/AGP divider, or does this board run the PCI and AGP bus at 33.3/66.6 regardless of the CPU setting?
TC and toomnymods both run this board with Athlon 4's. So if you guys read this - your experienced knowledge of this board would greatly be appreciated - as would anyone else's.
Thanks in advance for any assistance.
TOP 50 by New Years.
500,000 WU's by Valentines day.
