For the trace cut method you do not pull off any resistors, that is for the vdimm mod. (which if your steady enough, you do not have to pull the resistor off.)
I have a fully modded board and I would have to say the trace method was the most nerve racking for me. In all the post I read, no one really explained how to buff off the coating to get to the trace. I ended up using 1000 grit sandpaper, folding it a few times, and using the edge to do it with. It was nerver racking in the manner that I did not know how deep the trace went, I was afraid I was going to sand through it.
Just a lil heads up.
