nibler
Ozzman
ive heard of something called a nibler or something cant really remeber.. and it said it was about 10 bucks at radiodshack or something and that it does a pretty good job at making blowholes.. can anyone confirm this?
d03boy
Nebraska
Tin Snips
It's basically tin snips that cut a more precise area, and instead of being a long straight line cut, its more of a "biting" style... not too sure how they work, i guess they'd work just fine if you took enough time to use them although im sure you'll have to drill a starter hole for your fan hole before you can use the nibbler
...d03boy
dew042
minnesota
yeah.... i bought one. with patience one could make a nice blowhole....
you start with a pilot hole and basically every time you cut you get a nice clean 3mmx7mm chunk cut out.
its NOT fast, but it is clean. it works for pretty thick steel. I bet it would be just like butter going through aluminum.
radioshack has them...
dew.
Arkaine23
Captain Random Senior Evil
nibbler
Got one from Radioshack so I could turn an 80mm blowhole into a 92mm blowhole. Not really much to trim on that job, but it took at least 10 minutes and I had a small blister afterwards.
You also need a metal file to clean up the burrs.
stool
Senior Member
Albany, NY
Here's a pic of a nibbler;
The other guys are right...nice, clean cut, but takes some work. Saves a lot of cash instaed of buying a Dremel, and you get the benefit of a manly handshake after cutting a few blowholes.
Jeniva
Greensboro, North Carolina
or buy a whole saw..there arent to many tools out there better for cutting a hole then a hole saw....i have an 80mm hole saw and a 120mm..there fast, clean and not to expencive
Acko
UK
If you want all these different size holes & no blisters you can`t beat a good quality Jigsaw, start off with a 10mm hole & away you go. any size, any shape, you can cut wood, metal, plastic you just have to change the blade depending on the TPI (teeth per inch)
Acko
O
Ozzman
so how much is it? and is it called a nibler at radioshack?
O
Ozzman
hmm i guess i cant lose for 10 bucks.. just hope i dont end up with atritise (if that is how u spell it.. i cant spell for ****)
