- Sep 12, 2006
I have an Asus A8N32-SLI Deluxe Motherboard that I am trying to figure out how to overclock pretty much everything
I have read so much on overclocking, searched for others successful settings etc and I am still confused. I am not a noob when it comes to computers, but this overclocking thing has me totally confused.
I read things about multipliers, core voltages etc and when I go into the BIOS I cannot seem to figure out where and what to set. I was able to overclock my video cards via the nVidia control panel after using nVidiaTweak, that was easy, a couple sliders, test, and I was good to go.
Now I want to push my CPU, PCI-e, and Memory a bit futher adn know that the hardware I have is capable of it, I just do not understand what to do.
Does anyone know how to overclock on a A8N32-SLI Deluxe board? If so, what and where do I go in BIOS to get started? What areas should I work with and adjust till I find the "Sweet spot"?
I have the AMD Athlon Manchester Dual Core 4200+ 2.2Ghz and I have read everywhere that it can easily handle being pushed to 2.8 - 3.0 w/air cooling.
How?
Here is what I am working with in terms of hardware:
Antec P108B Triple Insulated Mid-Tower Case w/air Filters & 5 x 120mm case fans
HIGH POWER 560w NVIDIA SLI Certified supply Active PFC (3 x 12v Rails & Modular cabling)
AMD Athlon X2 4200+ Dual Core 2.2Ghz Manchester CPU
Zalman CNPS7700 120MM Pure Copper CPU cooler & Fan
4 x Patriot 1GB Low Latency 2-3-2-5 at PC3200 400MHz (4GB Total)
1 x 74GB Western Digital Raptor SATA II 10,000 RPM HD (Main)
1 x 250GB Western Digital 7,200 RPM IDE HD
1 x Maxtor 55GB IDE 7,200 RPM HD
1 x 120GB Acom External USB 7,200 HD
1 x USB2.0+eSATA External + Seagate 500GB 7200RPM 16MB HDD
1 x DVD/CDROM Read/Write Drive
1 x DVD/CDROM Drive
2 x BFG Nvidia 7900 GT OC 256MB Video Cards in SLI Mode
Zalman VF900-CU GPU Copper Heat Sinks/Fans
Audigy ZS Sound Card
Logitech G7 Cordless Gaming Mouse
Cyber Snipa Metal Gaming Mouse Pad
Gateway Standard Keyboard
21" Gateway HD Widescreen Monitor 4ms Response time - 1680x1050 Res
Logitech Z-5300e 280W THX Certified 5.1 Surround Sound Speakers
How?
1 x DVD/CDROM Drive
