the easiest way is to raise voltage in biosCan the volts be changed in CPUCool
Foxie3a said:15FSB isn't enough to start noticing changes, atleast not drastic ones.
If you pick out your hardware carefully, you can do nice things, even on stock cooling...
On my box it says my voltage is 1.55 max. Although it runs fine at 1.47v.
slix_88 said:I would just like to know which frequency is perfectly stable for a Northwood 3.0GHz running on default volt (1.5v i think)? Can the volts be changed in CPUCool? If so, how?
