There is a better chance that it will do better, but nothing is guaranteed. I had 1 low VID Q6600 that ran incredibly hot, but it did run 500FSB easily. I had another low VID Q6600 that OC'd very well, and ran cool. For the most part low VID Q6600's are a good thing!
That's actually pretty typical for 45nm CPUs. It doesn't seem that the VID has any correlation w/ OC potential on 45nm CPUs. Batch number is a better indicator.
You have the same VIDed chip as me and mine does really good. see the sig
i had an Artic cooler freezer pro 7 for a cooler and i could take mine up to 3.4 with that and i think i used 1.32v to get that.
have you tried fsb@ 400 and multi @ 8??
I also had AF7, but replaced it with Noctua. Not much of an improvement in temps, as i excepted. Tried 3.4GHz couple of times, the voltage was around the number you mentoined (1.32~). But, the temps arent good. I was hitting 70C under full load.
My Q6600 ran at 70-75*C under full load at 3.6GHz. I wouldn't be afraid of the 70's, but I would definitely try to stay below 80*C.
Basically, keeping your distance to Tjmax > 20*C is a good rule of thumb. I like to run the 45nm CPUs a little cooler, but the 65nm CPU's can handle it IMO.
