explorer (May 14, 2001 07:04 p.m.):
I have a GF256 with 32 mb of SDram that is oc'ed with the core at 170 and the memory at 175. When I boot up I get an error message that says "Error loading nvqtwk.dll
System can not find the file specified" I also get that when I open up or change any of the settings in NVmax. DOes it have any effect on my computer or does anyone knoe anything else abou it?
Thanks
The file nvqtwk.dll refers to a file which is used in the GL setup used by the Gforce and you may be able to get it again by downloading another GL setup from
http://glsetup.com or finding a loose version on
http://dogpile.com
it should be placed in your windows/system folder.
NVmax displays noticable improvements on my Gforce which are backed up with improved benchmarks till I exceed 170 mhz
If you want me to send you the file.. post your email and I will forward it to you
Duron 800 @ 1050 with Global Win FOP-32 (140 x 7.5)
Abit KT7A-Raid Mobo
512 mb (133 mhz Crucial Stuff CAS 2)
Hard Drive Cooler
Elsa Eraser X2 Gforce with Blue Orb (modified to display as a Quadro and overclocked
http://www.tweakhardware.com/guide/quadro/ )
Sound Blaster Live Value
Full Tower with 5 (120 mm) case fans with seperate PSU
