- Jun 7, 2012
Just got the NZXT Phantom 410 case and have been setting the hardware up.
The case has a fan-controller slider up top that is supposed to control the case fan speeds (there are 3 settings). I have everything plugged in correctly (I think) and all the fans are running, but I am unable to adjust their speed using this slide control; it does nothing. The fan are just going at their preset speed.
The NZXT user manual tells me next to nothing, so I figured I'd ask you guys. Help!
