- Jul 27, 2010
Hi!
This is my first post here, but from what I gather there`s a lot of competance here
Hardware:
Gigabyte GA-X38-DS5
4x Crucial Ballistix 1GB, Ballistix 240-pin DIMM, DDR2 PC2-6400 (BL12864AA80A)
Intel Quad 6600 (G0 stepping)
Radeon HD 4870
Corsair H50 water cooler for the CPU
________________________________________________
BIOS settings:
Robust Graphics Booster - Turbo
CPU Clock Ratio - 9X
CPU Frequency - 3.60 (400x9)
CPU Host Clock Control - Enabled (of course )
CPU Host Frequenzy - 400
PCI Express Frequency - 100 Mhz
C.I.A.2 - Disabled
Performance Enhance - Standard
System Memory Multiplier (SPD) - 2.00A
Memory Frequenzy (SPD) - 800
DRAM Timing Selectable (SPD) - Manual
Ram Timings 5 - 5 - 5 - 18
CPU/PCIEX Clock Driving Control - 800mV
All volts normal except;
(G)MCH OverVoltage Control - +0.025
CPU Voltage Control - 1.49375V (Normal 1.23750V)
Loadline Calibration - Enabled
______________________________________________________
So basically, what I`ve done is upping a bit here and a bit there. It runs Windows fine, and I can also benchmark with 3d Mark 06 and Vantage without problems.
Then I read someone who did 3.6Ghz at 400x9 and voltage so and so. So I decided I wanted to try that.
Earlier when I`ve overclocked a bit, I used Prime 95 to test it. This time I haven`t. I know, that might be a stupid way to go, but I didn`t have the patience.
Now, when I run Prime 95 with the settings above the workers fail after a few minutes. I use Core Temp and it maxes to a temp around 72 Celsius, which I know is pretty warm, but I figured if it lies around that when doing Prime 95, it should be ok for some gaming.
What I would like is some tips to what I should do now, except setting it to standard and testing it with Prime 95 everytime I up it a bit.
Anyone got an idea? And please, be constructive.
Thanks!
Hardware:
Gigabyte GA-X38-DS5
Radeon HD 4870
BIOS settings:
C.I.A.2 - Disabled
Thanks!
