Hi All.
I am a writer for the Danish Overclocking page http://wwww.overclocking.dk/ And i have made an application, that will:
-Calculate the heat dissipation of your overclocked CPU
-Calculate the C/W value of your Cooler, after which you can compare your cooler with other coolers.
-Calculate your CPU temperature with a specific CPU / cooler
- Calculate the memory bandwidth of certain memory types, at certain speeds.
Appart from the above, this app. works as a complete list, with specs for ALL AMD / Intel CPUs since 500MHz, new models will be added.
Get the Proggie here:
http://www.overclocking.dk/download.asp?mode=show&id=223
Check it out, and tell me what you think, alteration suggestions will be taken into consideration for the next version!
