Theoretically
, why can't the system bellow be ran from a 380W PSU?
First, the system:
1. 8800GTX alone = 132W full load, 70W idle.
2. e6600 @ 3.6GHz with 1.47v vcore actual = 135W @ 100% utilization.
source:
http://www.extreme.outervision.com/psucalculatorlite.jsp
3. 4x1GB DDR2 RAM.
4. 2xSATA 7200RPM HHD and DVD burner.
5. P5W64 WS Pro motherboard.
6. 4 pretty low-power fans, including yate-loon slow inside the tuniq and whatever is inside of the 8800GTX.
7. misc. extension cards that come and go
8. PCP&C 750W Silencer
1 and 2 are the biggest draw of power, 3 to 7 really don't consume all that much. CPU and the video card then are the parts to worry about.
How much power does the whole system use? According to the Kill-A-Watt gadget from P3 International, PSU draws form the wall (I am rounding up):
At idle:
250W with 2A
Running CSS video test (I tried to spice things up by running orthos at the same time but the load didn't change):
380W with 3.2A
The 750W Silencer hits 80+ efficiency above 150W and keeps it till 600W load according to this review:
http://www.pcper.com/article.php?aid=374&type=expert&pid=5
Round up the efficiency to 80% and that will give us:
380W/5*4=304W of real power being consumed by the system under full load.
Give it a bit of a buffer to stay on the safe side and it looks like all I need is a 380W PSU for that system.
So, lets pick a modern 380W PSU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371005
let's see now. 2x12v rails, each at 17A.
the juice the components need to run at full load:
8800GTX - 132W/12V=11A
e6600 @ 3.6GHz - 135/12v=11.25A
Seems to be plenty left for whatever the rest of the system needs.
The PSU is rated to draw up to 6A form the wall. All my system needs is 3.2A at full load. So we seem to be safe there as well.
OK now, am I making a mistake somewhere? Or tell me some other reason why the system above cannot be ran from a 380W PSU
