- Oct 18, 2010
I've had this system for years. Never really wanted to OC much (just a little). Now I want to see what it will do before I upgrade.
CPU: Athlon x2 64 6000+ (125w)
Mobo: Abit AN9-32x
RAM: Corsair XMS2 DDR2 800 (2x1024)
PSU: OCZ 750w
GPU: 2 9800GT's in SLI
The original problem was the CPU getting hot (70c was not uncommon @ stock speeds & cooler). Just installed the Corsair A70 and temps aren't getting above 51. However, something won't allow me to OC the CPU much. Here's what I got:
FSB: 200MHz stock, now at 280
CPU multi: 15 stock, now at 11.5
I left the RAM timings alone, they are at 5-5-5-18 (supposedly capable of 4-4-4-12)
Increased voltages as necessary
I think I could eek out a little more FSB, but N-bridge chip is getting a little warm at 60-65. However, I'm pretty happy with the results FSB-wise. DDR2 800 is running at over 1100 and it shows. Things are so much "snappier." Currently, everything is stable after lots of testing with SuperPi and Prime95.
However, there is a problem: The higher OC I go, the more my fps suffer. FarCry 2 frames are sucking. There is 'jumpiness' in Mass Effect. Something's off. I can tell it's not the RAM, heck, it's the only thing working well. If I raise the multi to 12, I can't get through post no matter the voltage. I'm pointing the finger at the CPU. What's wrong and what do I do?
Mobo: Abit AN9-32x
PSU: OCZ 750w
