I just got a sweet monitor in the mail yesterday...and as I was taking it out of the box and plastic wrap....I used a knife
As I was cutting the plastic wrap...I sawwed into the permenantely attached VGA cable. The monitor is a FE991SB-BK NEC Mitsubishi.
It still works (im using it right now).
I can see some of the copper inside the wire where I cut it though.. Sometimes when the copper is touching the monitor doesn't show anything and goes into a power down state (like when you turn the pc off). When they aren't touching it works fine (in fact i'm using it now).
I can see a few copper shreds..and then a small black covered wire was cut also...
I just blew 279 bucks on this thing...and I'm pretty mad at myself.
I was wondering, if anyone knew how much it would cost to replace the perma-attached VGA cable on this monitor. If possible even...
I'm taking it to a computer shop tomorrow though... I hope someone here can answer my question
