hi guys;
it's been a while since i build a new pc...just doesn't have much free time anymore.
below is the list of parts, that are in this build, and most of them were purchased due to rebate or cheap...etc
Intel E6750
Abit IP35-E
G.Skill 4GB 2x2GB 4-4-4-12 2.10v
Scythe Infinity 1000 cooler
BFG 8800GT OC
Samsung SATA DVD burner
Maxtor 320GB SATAII
Cooler Master 600W Extreme Power supply
Cooler Master Aluminum Case
ok, in the bios, the only changes i have made so far is running 2.1V for the memory at 5-5-5-15, and 1.4vcore (in bios, but only shows as 1.36v in cpuid). with these 2 settings, the pc will run stable at 3.6ghz w/o problem, but i can't get it to stable at 3.7 or above.
with that vcore, the temp that are showing in the core temp is 63-65 under 100% cpu load via prime95.
since this board only have passive heatsinks for the north and south bridges, i'm not sure how much voltage i can run on them.... any suggestion for me to tweak?
thanks
Intel E6750
Abit IP35-E
BFG 8800GT OC
Maxtor 320GB SATAII
thanks
