- Sep 27, 2011
so this is my build i have i5 2500k with an asus p8p67 mobo EVGA GTX 570 16gb of g.skill 1333 4x 4gb sticks 800wat Rosewill PSU and a Zalman cpu fan a cooler master HAF X case 60gb OCZ ssd 1.5TB WD black getting the cooler master v8 in 3 days
ok so my first thing is i use the Tpu setting so it overclock's it at 4.3ghz my idle temps are 30 to 40 and underload low 60s i have no prob overclocking to 4.8ghz with 1.36vc my prob is when i overclock no matter what i do my 3d mark goes down i will post links to 4.3 and 4.6 just to show you how big of a difference it makes and have in mind only the multiplier is change and i think i read on alot of websites that up to 4.6 nothing needs to be changed it can all be set on auto here are the links
Edit my GPU is Clock same in all of this at 800 coreclock 1464 shader clock 2040 memory clock temps underload low 70s at fan 85% is as high as it goes
defaults with TPU on http://3dmark.com/3dm11/1903343
same thing 4.6 with everything on auto http://3dmark.com/3dm11/1903632
boots up runs fine even stable with prime 95 over night i dont have any prob overclocking what so ever my prob is whats with 3d mark going down as i go up my cpu seems really good i can run at 4.8ghz no prob at like 1.36 1.37
and my heat does not really move it pretty much stays the same so if any one could help maybe cause i just dont get it at all im kinda tired of trying frist form iv been on in years
