- Dec 14, 2010
Sounds like you got lucky and got a tougher one.
With my Phenom II 965 BE I hit instability around 55-60°C.
That happens, usually when you need a lot more Cpu V. You may be nearing the point where you're going to have to really pour the voltage to it to try and get it higher. You'll know you're close with the voltage, when you just lose a worker or two. Have you raised the Cpu NB Voltage at all?No BSOD, just restarted on its own??
I'm not understanding the question.Will the ram frequency being to high show up more with a higher CPU clock?
YESDo you have the 140w version?
The BSOD I got during start up after the last shutdown was a code 50. That has to do with RAM (from what I have read). It was suggested earlier that my RAM frequency was high. Would a higher CPU clock make that problem more apparent?
I've never seen it fluctuate 5-10 mhz but I have seen it fluctuate. I'm pretty sure it's just a software issue with Cpu-Z.I am curious if it is normal for the FSB speed to fluctuate during Prime95? Mine did 5-10 mhz from time to time. That in turn would drop my CPU clock rate do 4.1 or so. A few times to 4.
If you're running Prime Blend some tests will stress the Cpu more then others. I have seen temps on certain test higher then others as well.Also my temps seemed to be the highest when it was running 8k - 14k FFT length tests. On the larger ones the tempos dropped 3-4 deg.
