- Apr 1, 2008
- Mechanicsburg PA
I recently built my first computer, and today I decided to try to overclock to 3.0Ghz. I got everything stable ran Prime 95 for an hour with no issues. However my core temps were a little high. Core 0-60, Core 1-59, Core 2-52, Core 3-50. this was at full load running prime. at idle I'm at 42, 39, 37, 36. My N/B temp was at 47 the whole run, and is at 44 idle. I'd really like to get the temps down while under load say around 50 to 55 max. (temps are from CoreTemp, & N/B temp has a thermal sensor on it ran to my front panel)
I'm running an Asus Maximus Formula bios v1004, Q6600, air cooled w/Asus Slient Knight II
Here is my bios set up:
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting :9
FSB Frequency : 333
FSB Strap to North Bridge : 333
PCI-E Frequency: 100
DRAM Frequency: DDR2- 1066
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 12
RAS# to RAS# Delay : 4
Row Refresh Cycle Time : 55
Write Recovery Time : 5
Read to Precharge Time : Auto
Read to Write Delay (S/D) : 9
Write to Read Delay (S) : 5
Write to Read Delay (D) : 5
Read to Read Delay (S) : 4
Read to Read Delay (D) : 6
Write to Write Delay (S) : 4
Write to Write Delay (D) : 6
DRAM Static Read Control: Disabled
Ai Clock Twister : Auto
Transaction Booster : Disabled
CPU Voltage : Auto
CPU PLL Voltage : Auto
North Bridge Voltage : Auto
DRAM Voltage : 1.88
FSB Termination Voltage : Auto
South Bridge Voltage : Auto
Loadline Calibration : Auto
CPU GTL Reference : Auto
North Bridge GTL Reference : Auto
DDR2 Channel A REF Voltage : Auto
DDR2 Channel B REF Voltage : Auto
DDR2 Controller REF Voltage : Auto
SB 1.5V Voltage : Auto
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU VOlt
Voltiminder LED : Enabled
CPU Spread Spectrum : Auto
PCIE Spread Spectrum : Auto
Advanced CPU Configuration
- Ratio CMOS Setting : 9.0
C1E Suppport : Disabled
CPU TM Function : Enabled
Vanderpool Technology : Enabled
Execute Disable Bit : Enabled
Max CPUID Value Limit : Disabled
USB Configuration
USB Functions: Enabled
Legacy USB Support : Disabled
In the Bios Hardware Monitor I have the following:
Vcore Voltage 1.240
Cpu PLL Voltage 1.600
N/B Voltage 1.360
Dram Voltage 1.952
FSB Termination Voltage 1.328
S/B Voltage 1.072
DDR2 Controller Ref 0.976
S/B 1.5v 1.520
3.3v 3.264
5v 4.944
12v 12.040
I would like to lower my CPU & N/B Voltages, but not sure where to start, or where to set them at, or if there is any other voltages I can lower to get better temps.
I'm very new to overclocking this is my first time trying, your "How to Overclock a Q6600" sticky at the begining of this forum was very helpful, got me to this point, just got to get it a little cooler.
Thanks, Rick
Extreme Tweaker
FSB Frequency : 333
CAS# Latency : 5
RAS# Precharge : 5
CPU Voltage : Auto
DRAM Voltage : 1.88
USB Configuration
Vcore Voltage 1.240
N/B Voltage 1.360
Dram Voltage 1.952
S/B Voltage 1.072
S/B 1.5v 1.520
3.3v 3.264
5v 4.944
12v 12.040
Thanks, Rick
