Hi all,
I`ve p4 2.4 northwood 533mhz old cpu I want to oc this to 2.8-3.0 with stock fan.. Now I tryed 2.700 (for test) seems no prblem.. voltage is default pci agp 66mhz. Whats the best combination for me to go 2.8-3.0 with stock fan ? Here is my specs:
Epox EP-4PDA2+ Intel 865PE Samsung 512*2 dual ddr400 cl3
Field Value
CPU Properties
CPU Type Intel Pentium 4
CPU Alias Northwood
CPU Stepping D1
Engineering Sample No
CPUID CPU Name Intel(R) Pentium(R) 4 CPU 2.40GHz
CPUID Revision 00000F29h
CPU Speed
CPU Clock 2713.2 MHz (original: 2400 MHz, overclock: 13%)
CPU Multiplier 18.0x
CPU FSB 150.7 MHz (original: 133 MHz, overclock: 13%)
Memory Bus 188.4 MHz
DRAM:FSB Ratio 5:4
CPU Cache
L1 Trace Cache 12K Instructions
L1 Data Cache 8 KB
L2 Cache 512 KB (On-Die, ECC, ATC, Full-Speed)
Motherboard Properties
Motherboard ID 03/19/2004-Springdale-PE-6A79APADC-00
Motherboard Name Epox EP-4PDA2+ (5 PCI, 1 AGP, 4 DDR DIMM, Audio, Gigabit LAN)
Chipset Properties
Motherboard Chipset Intel Springdale i865PE
Memory Timings 2.5-3-3-7 (CL-RCD-RP-RAS)
PAT Disabled
SPD Memory Modules
DIMM1: Samsung M3 68L6423ETM-CC4 512 MB PC3200 DDR SDRAM (3.0-4-4-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz)
DIMM3: Samsung M3 68L6423ETM-CC4 512 MB PC3200 DDR SDRAM (3.0-4-4-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz)
BIOS Properties
System BIOS Date 03/19/04
Video BIOS Date 04/01/15
Award BIOS Type Phoenix - AwardBIOS v6.00PG
Award BIOS Message 03/19/2004 For Intel Springdale-PE Chipset
DMI BIOS Version 6.00 PG
Graphics Processor Properties
Video Adapter ATI Radeon 9600 (RV350)
GPU Code Name RV350 (AGP 8x 1002 / 4150, Rev 00)
GPU Clock 392 MHz (original: 400 MHz)
Memory Clock 202 MHz (original: 203 MHz)
Field Value
CPU Properties
CPU Alias Northwood
CPU Stepping D1
CPU Speed
DRAM:FSB Ratio 5:4
CPU Cache
L1 Data Cache 8 KB
Chipset Properties
PAT Disabled
SPD Memory Modules
BIOS Properties
