I just recieved my first Intel. A 3.0 NW in D1 stepping (SL6WK) with 12 capacitors on the back. I've tried to see how high I can push it, and it seems that I have to raise the vCore beyond 1.7x volt to be stable at 3.6 GHz (240 MHz fsb). My setup is:
P4C 3.0 NW SL6WK
Asus P4P800-E Deluxe
2 x 512 MB crucial ballistix DDR500
The PSU is a delta electronics, produced for chieftec. The specs are:
12V - 15A
5V - 25A
3.3V - 25A
I'm watercooling it with an EK Water Blocks head, which performs similar to DD TDX. My pump is an Eheim 1048 and my radiator is a swiftech mcr (3 x 120) with a single 120 mm fan at 7v.
The temps are rarely above 40 °C at full load and I'm dual prime95 stable for hours at 3.5 GHZ (fsb 233) at 1.5875 vCore at around 40 °C. I've disabled spread spectrum in Bios and I'm running 1:1 FSB/RAM with vDimm on auto and fixed AGP/PCI speed.
The vCore fluctuates and can vary 0,1-0,12 volt at full load and this of course gets worse if I raise the vCore.
I would love to get 3.6-3.8 GHz stable, but I'm afraid to raise the vCore above 1.7 volt as I've heard of the SDNS. Could it be my PSU that is limiting my overclock, or have I simply hit the wall with this northwood ? I am wondering if I should vdroop-mod the board, but I'd like to get some feedback on this first.
BTW If I run the fan at 12 volt, the temps never go above 40 degrees, so I don't think it's a heat issue, but as I've written, I'm totally new to intel.
Thanks in advance, and excuse my bad english, I'm from Denmark. Please tell me if I've left out any important information.
P4C 3.0 NW SL6WK
12V - 15A
5V - 25A
3.3V - 25A
