I found that the OV_CPU jumper seems to make high vcores (>1.4ish) much more stable, i got 50-75mhz more OC at each voltage then with the normal setting.
Make sure you check bios right away after you move the jumper, it changes the minimum to 1.225 and if you don't check the bios the PWM stays at the same rate, resulting in a ton of volts. Once you re-set it in bios it's nice and accurate as usual with the p5q pro.
Wish i had my 530j back, this might be the secret that would have unlocked higher clocks.
It let me wind my e5200 up to 4.33ghz! Still 150mhz out of the .2+ point section of hwbot, but it did get me some good FW scores. I think they're good at least, though my 3d scores need help. Crossfire wasn't working for beans (worked for one (1) 03 run, no more. Not sure whether it worked for 05 or not.
