- Nov 21, 2018
So seems like my manual oc is benching higher then when i run PBO.
System specs.
2700x
32 gigs 4 dims of Corsair RGB pro @ 3364 16-17-17-35
Gigabyte Gaming 7 wifi
Custom loop
PBO is topping me out just over 4.3. BCLK is 101 CPU llc turbo SOC llc medium soc set to 1.050v CPU voltage set to auto. Should i use a voltage offset? What am i missing here? Even when i manual oc to what the PBO is hitting under load benchmarks are still higher with the manual oc by a fair amount.
System specs.
2700x
Custom loop
