MadMacsMan
- Nov 13, 2018
So I have an Intel based system that I've had in its current configuration for over a year now and a few days ago I encountered a problem when I wasn't even using it at the time.
Here's the problem, I was downloading an update on steam when my computer seemed to just turn off, I wasn't looking at it or near it at the time, it was around an hour later that I noticed something was wrong.
When I looked at the system both my monitors were black except for a single dash ( - ) or hyphen was visible on one monitor. I tried to restart my machine and again it seemed to start okay, no beep codes, I heard the AIO pump and all the fans came on and the HDDs can be heard spinning up but again it just sat with the single hyphen on the screen.
I again powered the system down and removed the power cable from the PSU and held the power button down to dispel any charge that may have been left and plugged it back in. I got it to POST and entered the BIOS to investigate the settings on the off chance something had gone aerie. Nothing had changed and when I exited the BIOS and the system restarted it again sat on the black screen with a hyphen. I repeated the removing of the power cable and such and let the machine boot to windows.
I viewed the reliability log and the event viewer and there were no records of any system failures in either.
Anyone had this problem before?
My specs are as follows:
CPU: Intel i5-4460
MoBo: Asus Z97-P
RAM: Corsair Vengeance PRO 16GB 2400MHZ (Running at 1333MHZ due to not having upgraded my CPU yet)
GPU: MSO GTX 760 OC
PSU: Corsair CX600M
Drives: 1x 128GB SSD
1x 1TB 5400RPM HDD
1x 1TB 7400RPM HDD
Additional Cards: 1x ASUS wireless network card
CPU: Intel i5-4460
MoBo: Asus Z97-P
GPU: MSO GTX 760 OC
PSU: Corsair CX600M
1x 1TB 5400RPM HDD
1x 1TB 7400RPM HDD
