- May 10, 2009
Hi all, HWBot has yet again done a rulechange on us. The backstory is steeped in even worse favoritism than usual, but whatever.
Please examine the example screenshot below:
Everything in red must be present in EVERY screenshot, regardless of whether you have a link to the orb (required for top20 global) or not.
Please note the notepad document! This is "Results.txt", it can be found in the PCMark05 directory after a run. Results without this will, in theory, be rejected.
A number of people are carefully reporting anything without results.txt, so expect yours to get reported and rejected if you aren't a HWBot moderator.
This happened (given the current official truth, anyway) Jan. 1st. Anything prior to that is exempt. Anything after that must have results.txt.
If there is a result ahead of you that was submitted jan 1st or later that lacks it, report it. In theory it'll get taken down.
Have at folks! Just don't forget the bazillion requirements
