- Sep 4, 2005
- Thread Starter
- #61
I wouldn't expect BV's tweaks to make up for almost -100 mb of ram, load up 98 or Linux on that machine. That's like putting a economy car beside a mustang at a drag strip, Hmmm. That machine wasn't made for XP, like an economy car wasn't made for the dragstrip.
<Sigh>
From the original post:
This system is not really capable of being a useable XP box. We'll see if BV can help make it into one.
Onward and... upward?
So, if you crap out your XP install, just pop the disk in and Re-install again. How are you harming anything?
Because no back-up system is fool-proof, and the general idea is that you try and test it as little as possible. In other words, you don't go doing things that could break your install when you have nothing to gain from them.
Intresting that the tests you ran on the second machine, did show some small improvements... What I'm saying is BV's tweaks were free and you did show a very slight performance boost in some cases.
Interesting that you decry artificial benchmarks as invalid and useless, and yet you trot them out as evidence when it sorta proves your point.
Interesting also that the "real-world tests" which you claimed to prefer show the opposite of what you think, and yet you are silent about them.
I don't think you're interested in proving or contributing anything. You just want to have an argument. Basically, you're trolling. Stop it and go away.
I've had two set of memory now, matched pairs they call them. Speed binned at the factory to ensure consistancy. Yet one stick always overclocked just a bit higher than the other. If this is true then it must be the same for cpu's and motherboard and every other component in a computer. What does this prove? No two systems are the same, even if you use the same brand name components.
<sigh>
If you clocked them differently then the systems would be different. Jeez. The systems would be identical if you used the exact same timings and speed. What something is capable of doing is not the same as what it is doing at any given time.
This is an analogy:
Me: All oranges look alike.
You: This apple doesn't look like an orange. Therefore all oranges don't look alike at all!
I would like to see your tests done on newer equipment, just to see if the finings would be the same.
Once again, if performance increase is 0, then by scaling everything up, you multiply by 0. 0*X=0.
Hell the human eye can even benift from 200 fps? No, but it sure sells $700 vid cards
<sigh>
The point of $700 video cards is not to run games at 200fps. It is to run them at perhaps 50fps, but at a very high resolution and with anti-aliasing, visual complexity, particle effects and more, which the human eye very definitely can detect.
Are you done now? I posted all of this after a lot of effort, and all you have brought in is nonsensical comments and baseless detractions. If that's all you have I would appreciate it if you'd just stay out of the discussion. Unless you have something better to offer this will be my last reply to you. I find it disrespectful that you would treat what represents a lot of work in such a way.
