- Aug 5, 2002
Alright so this lovely intel cooler I've been using for a while think is on its last legs for unmount/remounting it.
Sadly it does the job nicely just one of the clips is no engaging properly anymore :/
Originally had a E1400 core duo in there (i didn't use the heatsink that came with it), was perfectly fine just upgraded to a E5200 using the same cooler I had on the E1400 (its off a E8400). So the temps are wonderful old was right around 60ish in LinX and the new sadly has the temp difference (52C/44C) its its getting the chip cool, just the one being that high stinks.
So right now debating if I should get a cooler for the setup. If I do, I don't want to spend much but don't want something that is junk either (its just me with that).
Currently the cooler does work, and probably will work just fine. Though will it harm the life of the CPU with such a temp variance in it? Can be from 6-12C that I've noticed so far though typically sits around 8C for the difference. Mine you this is a server PC and really the load on it isn't that great, just wanted a little better cpu (which I should of gotten in the first place) for when I do connect to it.
Guess wondering what would you guys do if it happened to you?
