I just read his thread and found it to be very true. I am willing to try it out with my current case.
Please tell me if it's a good setup.
2x80mm lower front intake (they're side by side so you can't see it in pic), blowing by the HDD to cool them down,
one 80mm bottom intake that's blowing air upward.
one 80mm lower rear intake.
one 80mm Side pannel Intake
2x80mm rear intake (currently set as exhaust because I don't have the 120mm top exhaust yet.)
one 120mm top exhaust. That top blow hole is currently about 130mmx140mm in dimension.
Also, there is a 80mm exhaust fan of the PS right above the CPU.
my 80mm fans are ~24-25cfm, so that's about ~168-175CMF intake, not including the air flow restriction.
What kind of 120mm fan that I can buy, since my ambient temp is pretty low, I'd want a strong 120mm fan about or higher CFM than my total intake? And where can I get it? I've researched into Nidec and heard that they made pretty good fans.
That setup would eliminate allmost all the heatspot on my case BESIDE the DVD drives area which I was thinking of getting that 5.25" "100CFM" blower from FrozenCPU, but I don't know if it worths it or not?
Thanks everyone and especially to Aeon's thread about stack effect.
