- Nov 25, 2001
- Niagara Falls, Ontario, Canada
The iwill board supports K6-2s, but you're probably limited by the FSB, depending on what's stable, you might only get 6x66=400, or 6x75=450 or 6x83=500 out of it. Remember of course that 75 or 83 will overclock the PCI bus. In general, a lot of boards with the 430 TX will support the K6-2s, but only up to those speeds. K6-2s are not multi locked, so there's no problem setting the 500 up to test it at 66x6 if you're happy running it at 400 until you find a better board. The K6-2+ is a little problematic in that it has some enhancements that older boards might not support well. For that chip one could really use a board with a SiS 530 chipset, or a VIA MVP3 or MVP4, or an ALI VI, real super 7 100Mhz+ chipsets. Then put a spare socket A fan on her, PC133 RAM, set the multi for 6 and bang up the FSB to 124 or 133
