I have a q6600 that I just oc'd to 3ghz easily (rev.b3:59c load:1.2675v) and I think I could get 3.2 before the wall.
Problem is this: scored a vg236h off eBay for $190 and it is only capable of 120hz at 1080p. I have quite a hard time pushing a consistent minimum of 100FPS in 5v5 and my min for 10v10 is 70-80 depending on the environment(smoke? Smoke n mol? Smoke mol and nades and machine gunners?)
I'd like to get as close to 120fps as my minimum so is my CPU bottlenecking my fps here or my gfx card?
Everything is up to date on my pc, bios, drivers, catalyst (different version vary none). My amd settings in catalyst are set to performance, all of them.
All my ingame settings are at low with AF on bilinear tho trilinear seems to give me a slightly higher avg with it dipping into 90s less often.
Ok so here's the detailed info:
CPU: q6600 3.0ghz (9x333) - (Artic freezer cooler)
MOBO: gigabyte ep45-ud3l
RAM: Kingston cas5 2x2gb ddr2 800mhz (no oc, runs 5:6 with FSB)
VGA: xfx hd5850 1gb (oc at 725mhz core/1025mem tho I'm no pro at VGA oc)
(Also a Accelero cooler is coming in for this card today) currently card tops out at 80c
PSU: Corsair 650w (can't remember which but it's the top tier model)
HDD: 64GB Kingston SSDnow (houses OS and CSGO only):500GB 7200rpm w/e brand
LAN: Realtek 8111c
SOUND: creative titanium x-fi 5.1
CASE: LANcool k58w modded with all cougar dynamic bearing fans set to max speed, 2x140mm top exhaust, 1x 120mm rear exhaust, 1x 140mm front intake, 1x 120mm front intake strapped into empty drive bays)
Not really sure what else to do with this system. Saving up cash for black friday, going to upgrade to a ddr3 z77 platform with a sata3 SSD, i5-3570k, and 2x8gb ddr3 (highest MHz I can get from a solid brand).
And so for now I want to game in a way that I can take advantage of this screen. When I solo bots the game is remarkably smooth and head shots are natural. When gaming with 30 or less ping (NEVER higher) I feel lots of stutter on this screen. Not lots but enough to make me wonder if where I'm shooting is what I'm shooting at or not.
Any suggestions?
LAN: Realtek 8111c
Any suggestions?
