- Jan 27, 2008
System:
CPU: Core i7 920
Mobo: GA-X58A-UD3R
Case and PSU: Antec Twelve Hundred 750
GPU: 9800 GTX+
Memory: G.SKILL 3x2GB 1600
Main HDD: WD VelociRaptor 300GB
Storage HDD: 500GB (already own)
Optical Drive: DVD Burner with LightScribe (already own)
Cooling:
Rad: MCR320-QP
Rad fans: Yate Loon 120mm D12SH12 High Speed x3 or x6
Pump: MCP655-B
Res: MCRES Micro Rev 2
CPU block: Swiftech Apogee XT
Chipset/MOSFET block: EK-FB KIT GA X58
Tubing: PrimoFlex Pro LRT UV Blue and Green
Fittings: ???
Clamps: Metal worm clamps (I think they're called?) from hardware store
Extras:
OS: Windows 7 Home Premium 64-bit for System Builders
Protection: AVG Antivirus+Antispyware 9.0 2Year
Case Fans: Yate Loon 120mm D12SH-124B High Speed x3 and Cooler Master 120mm Green LED x2
Lights: Logisys 12" Dual UV Cold Cathode Kit, Logisys 8" Dual Blue Cold Cathode Kit, and Logisys 8" Dual Green Cold Cathode Kit
Wire Sleeving: OKGEAR OK430UB UV blue cable sleeving kit and green
There isn't really a set budget as of yet and this build is by no means set in stone. I don't plan to water-cool the GPU because I don't play graphics intensive games. This computer is going to be doing my compiling and possibly video rendering/compression. I'm not sure if the PSU is enough with all the additions. As you can probably tell the color theme is blue/green. I plan to build an external tower for the radiator, and possibly build a completely custom case if I get the initiative. I think that's all I have to say about it so if anyone has any comments, suggestions, questions, etc they'd be greatly appreciated.
CPU: Core i7 920
Mobo: GA-X58A-UD3R
GPU: 9800 GTX+
Cooling:
Rad: MCR320-QP
Pump: MCP655-B
Fittings: ???
Extras:
