Hello. excuse my English first.
I have a problem with the E8400 clock on the G41M-S3 ASrock board
The DDR3 I use is 2x2GB https://www.kingston.com/datasheets/KHX1600C9AD3B1K2_4G.pdf
There was a problem with overclock if i have this Jumper set-up to overclock 1333FSB
https://www.manualslib.com/manual/348001/Asrock-G41m-S3.html?page=19#manual
It's the last one on the page.
What settings or jumper settings should I use if I want to get the CPU to 3.4GHz ~
I used the DDR3 frequency edit in the bios to able them going still lower then CPU frequency, which didn't help, I tried to turn off all utilities in the bios, increase the CPU Voltage to 1.3V~, but it didn't help too.
When using jumpers for default settings FSB-First 1-2,FSP-Second 1-2,FSP-Third 1-2 | I got to a maximum clock speed of 3.15 ~ GHz.
I would need to know how to set the BIOS so that it is possible to run the CPU at 3.4GHz ~ even though it would not be possible to use 1333MHz on RAM. Updated Bios v1.40.
Thanks for any reply.
Have a nice day.
Have a nice day.
