- Jan 23, 2005
- Hawaii
What awg wire are you using on the MOSFET banks? I like the housing you got, I think it could use more ventilation though. CFM on those AC fans?
Status?
Whenever my father-in-law is done with it. He has made progress (saw it over a weekend in August) and has all the parts (he was waiting on some shunts), it will just take time for him to complete it.
I asked him to take it and work on it, but it would take him more time to draw out his plans on paper than to just build the thing, both of which would happen in his spare time. Unfortunately that spare time isn't very plentiful...he still works at 68 and loves what he does (engineer). Loving what he does means 9-5 days are never and weekend work is frequent.
Oh yea, it has changed considerably. I haven't had an opportunity to make a diagram, but will make a rough one when I have time. No promises on time frame for it though. Since the schematic is in his head, it will be more of a rough guess than an actual schematic.
We've dropped the MOSFET idea; they couldn't hold the loads in a linear fashion. We're going with mostly resistive load and using transistors (like this one) to fine-tune it.
So I guess the diagram hasn't changed all that much, it's just heavier on the resistance side and lighter on the transistor side. The resistance is going to be "active" - we will use switches to load at roughly 10A/switch until the load is near where we want it, then we'll use the transistor bank the rest of the way with pots.
For the tester's meters (there just to get a ballpark during operation; real values will be measured with the LabJack) we're using a 5V wall wart and for the transistors we'll have a small power supply mounted inside. I think 12V, but I'm not positive on what voltage the transistors need for operation; haven't asked.
If you meant the power supply to test, we're burn-testing on an old Thermaltake 420W I left up there with him. Once we're satisfied it won't blow up again (or won't blow up the PSU), I've got a Cooler Master 850W unit ready to plug in.
As far as current loading, we're designing it to take 100A total on two +12V rails. It would have been one, but Oklahoma Wolf helpfully reminded me that some PSUs (such as the Corsair HX1000) actually use two discrete power supplies in one box. The other two will have capacity for 35A each on +3.3V and +5V. We're not going to bother with the -12V rail.
Ironically, the hardest one to get loaded as high as we need is the +3.3V. You have to get resistance so low (and still retain the ability to dissipate heat), it's quite a challenge. V=IR, or for this purpose of course I=V/R. So if you have large resistors that are difficult to get < 1ohm, 3.3V / 1ohm = a mere 3.3A. We've got a bunch of resistors parralleled up using a (relatively) small space and are up to ~20A so far. It's going to take some thinking to get it the rest of the way and still maintain some semblance of reasonable size.
