- Feb 2, 2004
- South Africa
Hi
It all really began with an idea that my best mate planted a few weeks ago.
But let's start with the background...
I had an XP 2100+ in my box, which had average temps (under load) in the region of 50C-55C, with a stock AMD HSF and some AS3. I knew this wasn't ideal, but wasn't ready to make any changes.
3 weeks ago I bought a 2800+ along with a Thermaltake "Silent Boost" (the dual ball-bearing version, as the supplier could not source the hydrowave variety). So I plonked my 2100+ into my girlfriend's PC along with the copper-base HSF from the 2800+ (even using the regular TIM pad). I was most interested to see that the 2100+ temp remained below 40C. It seems that even a copper insert helps, although sometime I'll replace the TIM with some decent thermal compound.
(note: please bear in mind that our climate causes average summer maximums of between 25C and 32C)
Having read around the Net that Shin Etsu compound is better than AS3, I got some Cooler Master Premium. It's just as awkward to apply as AS3, but for a different reason. Whereas the AS3 is a messy affair, the Shin Etsu stuff has a thicker consistency (almost resembling putty). I found that even with the decent compound and an all-copper heatsink + 80mm fan, my CPU still ran up to about 55C.
The next step was to improve my case's airflow. I have an Acer QF50 mid-tower, a fairly standard case. I added a rounded IDE cable for the HD and tidied up the PSU cables as best I could (bundled with cable ties). Then I added 2 Coolermaster 80mm fans: front intake and rear exhaust.
With all of this, I was impressed to see the case's temperature drop safely to a max of 35C, even on hot days with many hours of uptime.
This is where my friend's idea came to play. He mentioned have ducts taking the air from intake fans to where it was needed most. Something grabbed me, about having a neat duct from an intake fan. I'm not interested in cutting holes into my case, BTW.
Lots and lots of reading up on viable materials, brought me to this thread and clocker2's idea of using Sintra. I was despondent about the chances of finding such useful stuff locally. More research, a few phone calls later and I found a plastics supplier which could sell some Komatex to me, which is another brand of the same PVC foam-board.
I happily spent a whole Friday evening getting to grips with moulding this at home. I was able to fashion an experimental duct (a test tube, if you will). I realised that having a flattened 'S'-shaped duct which ended in a sharp bend over the CPU would be quite tricky. Still, I was satisfied that I had a material that could possibly do the trick.
My friend had suggested that before finally committing to building the duct, I might also try a mockup "side-panel duct" from cardboard, to see if ducting external air would be of much benefit. So I carried on to build one, with a slightly tapered duct which enclosed the CPU fan. As the Silent Boost's fan draws air in from its sides and top, I made sure that there was room around the fan housing and added a little collar to enclose its base.
Initially I ran the mockup as-is, for 45 minutes. With the CPU idle for 10 minutes, the case temp was 36C and the CPU temp was close at 35C. I then ran a few apps for 30 minutes, including Prime95's torture test. The case and CPU temps matched each other at 39C.
I installed an 80mm Tornado fan at the opening of the duct (almost 10cm away from the CPU fan. At the 15 minute 'idle' point, the case was 38C and the CPU was 33C. After 45min of playing Unreal Tournament 2003, the case temp was 39C and the CPU was 35C! It stayed at that temperature after leaving the PC running Prime95 overnight. I suspect that the lack of sound and video demands in Prime95, meant that one was not seeing maximum temps. Also, the duct did seem to hamper the airflow in the case, as I saw the temperature exceeding the values I have with my usual setup, by about 5C.
I think that seeing the CPU temp drop by about 15C proves how effective a side-panel duct is. Still, this is not what I'm interested in doing to my case. This lead me to PM the same 'clocker2', asking for suggestions for working with Sintra.
A wonderful suggestion was made, to consider having a duct from a rear intake fan, which is far simpler to build. I will need to angle the current (warm) exhausted air away, but I'm highly optimistic.
So, I'll be implementing this idea ASAP and updating the results here.
