- Aug 20, 2002
- Brooklyn, NY
I couldn't find a good definition of pump head here so I thought I'd add one.
[size=+1]Head - Defined[/size]
Head is a measure of fluid energy. It is used to describe the Specific Energy of a pump.
Specific Energy is defined as energy per unit of mass. For example, if we lift up a one-pound object by three feet, we say we have three foot-pounds of energy. It doesn’t matter whether it's a pound of lead or a pound of feathers; we still have 3 foot-pounds.
This is why head doesn’t change with the type of liquid being pumped. Whether pumping water, alcohol, or oil, a pump’s head rating is unaffected.
Sometimes Head is described as the resistance that a pump must overcome. While this may describe what’s going on while pumping, it is not technically correct.
[size=+1]Head vs Pressure[/size]
Pressure is not Head. Pressure is a force applied to an Area. For example, PSI refers to Pounds per Square Inch. The “Square Inch” part is the big difference between Head and Pressure. With Head, there is no Area in the calculation.
[size=+1]Types of Head[/size]
There are four types of head; Static Head, Friction Head, Pressure Head, and Velocity Head.
Static Head – Applies only to open systems, such as a waterfall in a manmade pond. It is the difference, in feet, between two water levels. So if the pump is at the bottom of our pond with a waterfall, then the Static Head is measured from the top of the pond water to the top of the waterfall (yes, the TOP of the pond water, not the bottom where the pump is sitting.) A pump's head rating is usually the maximum Static Head the pump can overcome.
In PC watercooling, the Static Head is always 0 because it is a closed system.
Friction Head – Also called Pressure Drop. It is the resistance to flow. When a pump pumps liquid through a component, that component creates a resistance to the flow of liquid. Typical components are tubing, radiators, fittings, and waterblocks. This resistance to flow is usually expressed in feet of head.
In PC watercooling, Friction Head provides 100% of the resistance to flow.
Pressure Head – Refers to the different pressure levels between two vessels. For example, if a pump must pump rainwater (collected in an open tank) to a second tank that is closed and slightly pressurized, then in addition to Static and Friction Head, the pump must also overcome the pressure being exerted on the water in the tank. Exist in open systems only.
In PC watercooling there is no Pressure Head.
Velocity Head – Refers to the energy required to accelerate the fluid. Exist in open systems only.
In PC watercooling, the velocity of the water is constant, so Velocity Head is 0.
The Friction Head of 4 ft of 1/2" tubing, at 2 GPM is 0.58 ft.
The Friction Head of 4 ft of 7/16" tubing, at 2 GPM is 1.141 ft.
The Friction Head of 4 ft of 3/8” tubing, at 2 GPM is 2.5 ft.
The Friction Head of 4 ft of 1/4” tubing, at 2 GPM is 20.58 ft.
This is why it is so important to use 1/2" tubing.
Search Phrases
What is Head
What is Pump Head
Definition of Pump Head
Definition of Head
Search Phrases
What is Head
What is Pump Head
Definition of Head
