i also have a BIX3 with three sanyo denki's on it. All you need to do is strap some powerful fans to your rad, then run them through a fan controller... mine is almost silent when i'm surfing and when i game i turn the fans up... and the volume too.
OK, I had another crazy idea. I realized that there's a real possibility I just won't be able to fit a BIX3 in my case. How about three fans with two 120mm radiators? The second radiator would get warmer air, though, would that cancel the benefits of such a setup?
if you had one fan blowing in on the radiator from oneside then another fan blowing in on the radiator from the otherside wouldnt there be a pressure problem with the airflow from both the fans running into each other and not passing through the radiator?
same with pull/pull if you had a fan on oneside pulling air from the radiator and a fan on the otherside of the radiator trying to pull air from the radiator youd have a problem finding any air for either of the fans to move.
