- Aug 16, 2009
Thanks RB1991 .....
Those are actually pretty good temps and you still have a bit of headroom, we generally recommend not exceeding 60*C core and 70*C socket temps. You should have no issues with getting a bit more from your OC.
One thing I had noticed in other postings in the forums with large air coolers in the build is the socket temp was considerably higher then the Core Temp and a big reason why I asked for the HWMoniter capture. That's not the case here and it looks like you have some decent airflow in your case.
Now all you should need to do is add a bit more VCore to get your chip stable @ 4.3.
Not sure if you really need to run your CPU LLC at Ultra High you might want to try one step lower on it as well. There is no need to run Prime for 10+ hrs till you have reached a point in your OC that you are happy with and don't plan to go higher till then 2 hrs of prime should be good.
