- Feb 8, 2017
- Minneapolis, MN
So Firstly I recently upgraded to a 7700k and it is one hot MOFO. I used this chip with my H220x (240mm) AIO(hybrid) system.
I was noticing temps in the high 70's low 80's at stock clocks when running p95 so thinking it was first my TIM application I reapplied my TIM and even went with another brand.. Temps however stayed the same.
So thinking maybe it was just producing way more heat that my AIO loop could handle I ran out and picked up another 240mm x 38mm ek radiator with 19fpi. I have good static pressure fans on it and everything is pretty quiet actually.
However after this upgrade my temps onlye dropped 3-5C across the board which does make them a little better, but still hotter than I would like.
I did some reading (after the fact unfortunately) on delta T.. So that being said I can run a prime95 stress test and measure the water temp with good fast reading cooking prop in my res (directly in the flow) and can see that while my room ambient is about 25C atm.. my water temp is only 30C. So according to the info I found that seems to be a really good Delta T
My question though is why is the water loop not taking more heat off the CPU die? The waterblock I am using isn't suppose to be bad.. so just trying to see what I can do to actually make the system soak up more of that heat.. if it is possible that is.
My knowledge of water cooling in the PC world is rather limited as I have only dabbled in it slightly. So hoping some more experienced people than myself can offer some information or tips.
