- Dec 13, 2001
I've got an interesting dilemma that just reared it's ugly head... I'm posting it here since it is a general hardware query/issue, but if it's in the wrong place, mods feel free to move it if necessary.
A recent build (listed in sig.) has been flawless since first boot. Fresh installs of everything, so there wouldn't be any problems. Everything was "up to date" as far as drivers and software is concerned and running sweet, not a glitch. The only thing that kept bothering me was windows was using the "stock" driver for the onboard "Realtek" audio (I opted to skip the purchase of an "add on" card since the "SupremeFx IV" was supposedly "one of the best onboard audio solutions" to date).
So my OCD got the best of me, I wanted to know what was missing beside some simple features I was used to having (I did notice I had no tone level control, or other "features" to alter the sound with the stock driver, and I'm used to being able to adjust treble, bass, etc. with other audio solutions)
So I installed the "updated" drivers and software for the onboard sound, and was happy to see upon reboot I was in fact, previously missing quite a few settings, and now had them, and many others with the updated driver and software.
Everything ran fine; several power cycles showed no issues. Out of nowhere, I started getting problems on startup where it would get to the log-on screen, and would hang there for over 3 mins. at the "Please wait..." prompt, then my log-on would come up, I'd log in, and be greeted with the message "Failed to connect to System Event Notification Service...", and my "Aero" wasn't working on the desktop as well.
As most people would, I assumed ok, something may have "glitched" with my video drivers, so I uninstalled and re-installed them to no avail, same thing happened with each reboot, EVEN when I decided to let windows install the generic driver for the video card. SO after some tracking and tracing (and finally using my brain), I found out that the AUDIO SERVICE was the culprit as it had thrown up some errors about being unable to start (thankfully they were recorded in the event logs, or I'd be pulling out what's left of my hair...)
So upon uninstalling the driver from device manager for the realtek audio (with the "uninstall driver software" checkbox selected), a fresh start yielded windows going back to its normal operation and installing the "stock" windows driver for the audio by itself, and everything is fine again.
Since I've rambled on long enough, the core of the problem is this... Any and all versions of the drivers I have downloaded and installed cause this to happen, and it is only the audio that is causing it, the only driver that works is the "stock" installed one from windows itself, but it has no adjustable options (other than being able to select speaker configuration and it sounds like crap!)
Anyone have a solution? because I've just about given up on the onboard, and I'm considering just getting a nice "add on" card. I was always against using onboard to begin with, but I was "assured" this board had one of the best options that rivaled some third party add on cards; now I'm not so sure... Help?
Thanks!
Thanks!
