I suppose I should post my video of the Enermax Revolution 1050W pulling over 1700W here right?
Nice video, but a bit misleading.
You know that the PSU might be pulling 1700W from the plug, but the real questions are:
How accurate is that kill-a-watt at those loads?
How efficient is the PSU when heavily overloaded?
And consequentially how much did the PSU really deliever at that time?
Let's say the kill-a-watt's readings are somehow accurate (I don't know about that).
That would mean that at an assumed efficiency of 85% the PSU would've delievered around 1445W at the time the power meter showed 1700W.
Then again seeing that the PSU is heavily overloaded I guess that the efficiency was a fair bit lower than 85%. Let's assume 75% in this condition.
So, the PSU would've delievered about 1275W at the moment the kill-a-watt showed 1700W.
What you showed is that the PSU can be overloaded. But that doesn't necessarily mean that it's one of the best PSUs. It just means that it probably won't die that easily when tortured.
Throughout your tests you probably overloaded the unit constantly by ~150W with peaks upto ~250W. So, in reality there is a bit of a difference between 650W and ~250W.
