hello everybody,
As some of you may know I am setting up a larger scale network than most and I am putting to use some 24 port gigabit switches by SMC (Tigerswitch 8624T). The switch does not get hot, barely gets warm. The fans however are extremely loud, even after putting the zalman fan resistor adapters on it... it's still loud and the change in character the fans went through has made it more annoying for my room mate. Less for me, but more for him.
The stock fans are some ADDA 40MM, I'm wanting to replace it with a quiter 40MM fan.
The stock airflow on these fans is rated at 7.7CFM, with the stock noise level being just under 30DBA. Does anybody know of any good fans that we can use to reduce the noise?
I'm looking for about 20DBA, something much closer to silent, but still able to do about 5CFM. These things sitting open case barely get warm, so I don't think massive (lol) 7.7CFM fans are required.
I'm asking because I want silent fans, and seems that noise is always understated and airflow overrated.
TLDR: I need silent 40MM fans (actually silent) that will do about 5CFM. Anybody know of anything?
