- Mar 5, 2002
- Bellevue, WA
After doing a bit of research on flat heat pipes, it appears that a flat heat pipe (such as used on the Scythe NCU-1000/2000) would be a much better solution to evenly spread the heat out over the base of a heatsink or waterblock.
It looks like the only flat heat pipes available are aluminum based, which would appear to be a drawback, but then again the total thermal distribution might be high enough that it leads to an improvement in temps.
Any thoughts?
Has anyone tried it?
Did it work?
Any thoughts?
Did it work?
