- Sep 29, 2011
The fan on one of my 560 Ti's is dying, just 1 month outside the warranty. MSI won't replace it so I need to get an aftermarket solution.
The only fan I found for the card is this one:
http://www.arctic.ac/en/p/cooling/vga/554/accelero-xtreme-iii.html?c=2182
I'm going to replace the fan on both my cards, so they both have the same amount of cooling, even though only 1 is defective.
However, I'm not sure if this cooler will work as it describes a height restriction. I'm not much of an expert, so I'm not really sure how to read the graph they provide or know if it will work.
I was wondering if someone here more knowledgeable on the subject can help.
They provide this information:
It's compatible with GTX 560 Ti's. I have 2 MSI 560 Ti Twin Frozr II cards.
It also provides this height restriction.
http://www.arctic.ac/fileadmin/ax3/height restriction_Accelero_Xtreme_III.pdf
My motherboard is a P8P67 Deluxe:
http://ca.asus.com/Motherboards/Intel_Socket_1155/P8P67_DELUXE/
My case is a CM 690 II Advanced NVIDIA edition:
http://www.coolermaster.com/product.php?product_id=6682
So, will it work? And will it work in SLi?
